Authenticate with fingerprint in INI file?
guest
Is there a way to add the fingerprint to the INI file to have the client automatically authenticate the host when logging into it for the first time?
Re: Authenticate with fingerprint in INI file?
Yes you can do it manually. Just authenticate on some machine, and accept the host key. It gets stored into the INI file. And then you can distrubute the INI file to other clients.
Fingerprint of public host key is public information. No need to encrypt it.
