Intermittent Interface
MrP4
When we start WinSCP and connect to a session it will go through and connect fine first time giving us the commander inteface. If we then close WinSCP, open it again, attempt to connect to the same session after we enter the password the commander inteface does not appear. The process is still running in the background. If I try to connect to a different session it tends to connect fine. If I wait for a little bit and try the first session again it goes through.
We are using version 4.3.4 (Build 1428) running on Windows 2008 SP2.
Port Number 22 with file transfer protocol SFTP-3.
We use the commander interface GUI
There are no errors received
Re: Intermittent Interface
