Scripted Transfer Requiring scp
akreitman
I need to start winscp in scp mode for a batch transfer The server I'm connecting to only supports scp, and the automatic fallback doesn't seem to work.
When I incant "winscp scp://user:password@ipaddr /command "put src dst", it says automatic actions are disabled for command line url addresses.
When my script file says
"open scp://user:password@ipaddr"
it responds "searching for host, host doesn't exist" and gives me a prompt. If I enter "open scp://user:password@ipaddr" at the prompt, it connects.
Is this a bug, how do I change the default protocol to scp?
Re: Scripted Transfer Requiring scp
You should do:
winscp /script=script.txt
Where script.txt is:
put src dst
I understood that you have tried this already. But give it one more chance anyway :)
