No sub-directories showing
Scott @ UCR
I upgraded to the latest winscp to transfer files between home and the University server. Problem is that with the previous version I would log in and all my sub directories would be showing including my download directory where I would put everything for transfering. Now all I see is my root directory and nothing else. The "list" command seems to do nothing. How can I get to my sub-directoryies?
Re: No sub-directories showing
If you try now the previous version of WinSCP, is it working correctly?
Do you use the same settings as in previous versions? Please note that SFTP is the default protocol since 3.5. In all previous versions it was SCP. Maybe you've used SCP before, but now you connect with SFTP.
If this does not help, please post a log file.
