Convert saved sessions from FTP to SFTP- how?
minty
I've got a whole lot of saved sessions using FTP. I'd like to keep all the details but use SFTP.
Is that possible, or do I have to go and enter all the session details again while choosing SFTP?
Cheers,
Minty
Re: Convert saved sessions from FTP to SFTP- how?
For each stored session, click Edit, choose SFTP and //Save//.
Or (if you are advanced user :)) you can update all sessions at once, by editing configuration storage. Registry or INI file. INI file may be easier for you to update, you can switch to it temporarily. Just remove all FSProtocol and PortNumber options. SFTP is the default.
Read:
https://winscp.net/eng/docs/config
minty
Excellent! Thanks for the swift reply.
