Can't open a directory beneath one with the same name
Marcel194
It's strange but it seems I can't open a directory when it has the same name as the parent directory.
Example http:\\JustATest.com\test\test can't be opened. Rename the last one to test_ and it works fine.
I'm using the commander mode, in FTP, on Win Vista professional, and I have the latest version (the previous one had the same error).
Re: Can't open a directory beneath one with the same name
Marcel194
Sorry for the late respons, but accidents can happen :-(
The log :
TYPE I
200 TYPE is now 8-bit binary
Cached directory change via "code" to "/software/code".
Getting current directory name.
Directory content loaded from cache.
Cached directory change via "gas" to "/software/code/gas".
There is a directory beneath "/software/code/gas" that is also named gas ("/software/code/gas/gas").
There seems no way to get there without renaming the directory above in - let's say - "/software/code/SomethingElse/gas".
prestersean
United States
I have the same problem as Marcel
[Background 1] TYPE I
[Background 1] 200 Type set to I
Cached directory change via "ss" to "/httpdocs/gallery/ss".
PWD
257 "/httpdocs/gallery/ss" is the current directory
I cannot right click "open" or "edit" either- the options are greyed out. I can get there via the directory tree, but I usually have that hidden.
Can you both delete following registry key:
HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\CDCache
And then try again?
If it won't help, please email me complete! log file. Thanks.
prestersean
United States
Re: any joy
GGman wrote:
hi there was there a resolution to this pls as have the same issue? thanks
You have to click on the actual file name, not anywhere to the right (empty space, date, etc)
