Disconnect after trasnfer completion
613org
Is there any way to have the program automactically disconnect itself from the server, once the file transfer is complete?
Jimmy
Disconnect After Transfer
When I check the Disconnect After Transfer, I get prompted with the following Message:
Operation was successfully completed. Connection was closed. Do you want to reconnect.
OK Reconnect
I select Disconnect after Transfer so I would not have to see any more dialog boxes.
I it possible to remove this message?
jimmy
Re: Disconnect After Transfer
It is not true. When you select "Disconnect after Transfer", program should disconnect. This is what it does. It does not say anything about exiting the program. What is the problem with the message?
Jimmy
As it is now, the program asks if you want to reconnect. It would be better if it just exisited with out asking anything, ie. no option to reconnect.
Just my $.02.
Jimmy
I understand what you ask for. I just do not understand what's the problem with the message? I think that it is better as it is now.
Jimmy
If I Check the box that says Disconnect after transfer, then I just want the program to close, otherwise I would just click the X to close it.
Jimmy
