Prefences>Transfer>Upload options>Set permissions not obeyed
fade2gray
4.3.2 & 4.3.3
Uploading from XP box to Ubuntu box directories and files are always transferred with default permissions i.e. 755 and 644 respectively, yet I have the box checked and set to rw-rw-r-- (+x). I would like to see transferred directories and files as 775 and 664 (I would like group writeable for dirs and files).
Any advice please?
Re: Prefences>Transfer>Upload options>Set permissions not obeyed
fade2gray
Problem solved
Although I had changed permissions from rw-r--r-- (+x) to rw-rw-r-- (+x) in Preferences/Transfer tab, I had not changed permissions in Preferences/Transfer/Presets for the auto preset I had configured for binary transfers.
Thanks for reading.
