Don't create folder if not existing
Azamat
I am using winscp scripting. So, when I upload files to some directory, it uploads even if directory is not existing. I don't want winscp to create a directory on the remote server, when uploading files. Is it possible to change that setting?
Re: Don't create folder if not existing
What protocol are you using? Please post a full log file showing the problem.
This is not actually a problem. I am using FTP protocol. I just don't want WinSCP to create a folder on a remote server if not existing. Say, this is my script:
start.bat:
winscp /log="log.txt" /script="script.txt"
and script.txt:
option batch on
option reconnecttime 5
option transfer ascii
open myFTPserver
put "D:\file1.php" "D:\file2.php" "D:\file3.php" ./www/example.com/noSuchFolderOnRemoteServer/
close
I am simply uploading 3 files and it is not only uploading, but creating "noSuchFolderOnRemoteServer" folder and uploading those files there. I just don't want WinSCP to create a folder if not existing and maybe show some error like "no such folder" or something like that.
This is just script, but not GUI, you understand I know :)
So, is it possible to turn off automatic folder creating, when not existing?
Diky moc for reply :)
WinSCP just does not create the directory automatically. So please post a log file to let me see what's happening there.
Azamat
Ok, here you go:
. 2011-07-29 17:02:32.625 --------------------------------------------------------------------------
. 2011-07-29 17:02:32.625 WinSCP Version 4.3.4 (Build 1428) (OS 6.1.7601 Service Pack 1)
. 2011-07-29 17:02:32.628 Configuration: C:\Program Files\WinSCP\WinSCP.ini
. 2011-07-29 17:02:32.630 Login time: Friday, July 29, 2011 5:02:32 PM
. 2011-07-29 17:02:32.630 --------------------------------------------------------------------------
. 2011-07-29 17:02:32.630 Session name: Knock3 (Stored session)
. 2011-07-29 17:02:32.630 Host name: ftp.knock3.com (Port: 21)
. 2011-07-29 17:02:32.630 User name: johndeeray (Password: Yes, Key file: No)
. 2011-07-29 17:02:32.630 Tunnel: No
. 2011-07-29 17:02:32.630 Transfer Protocol: FTP
. 2011-07-29 17:02:32.630 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2011-07-29 17:02:32.630 Proxy: none
. 2011-07-29 17:02:32.630 FTP: FTPS: None; Passive: Yes [Force IP: No]
. 2011-07-29 17:02:32.630 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-07-29 17:02:32.630 Cache directory changes: Yes, Permanent: Yes
. 2011-07-29 17:02:32.630 DST mode: 1
. 2011-07-29 17:02:32.633 Connecting to ftp.knock3.com ...
. 2011-07-29 17:02:33.033 Connected with ftp.knock3.com. Waiting for welcome message...
< 2011-07-29 17:02:33.273 220 ::ffff:172.17.3.9 FTP server ready
> 2011-07-29 17:02:33.273 USER johndeeray
< 2011-07-29 17:02:33.510 331 Password required for johndeeray
> 2011-07-29 17:02:33.510 PASS ********
< 2011-07-29 17:02:33.803 230 User johndeeray logged in
> 2011-07-29 17:02:33.803 SYST
< 2011-07-29 17:02:34.040 215 UNIX Type: L8
> 2011-07-29 17:02:34.040 FEAT
< 2011-07-29 17:02:34.280 211-Features:
< 2011-07-29 17:02:34.280  MDTM
< 2011-07-29 17:02:34.280  REST STREAM
< 2011-07-29 17:02:34.280  SIZE
< 2011-07-29 17:02:34.280 211 End
. 2011-07-29 17:02:34.280 Connected
. 2011-07-29 17:02:34.280 --------------------------------------------------------------------------
. 2011-07-29 17:02:34.280 Using FTP protocol.
. 2011-07-29 17:02:34.295 Doing startup conversation with host.
> 2011-07-29 17:02:34.295 PWD
< 2011-07-29 17:02:34.535 257 "/" is the current directory
. 2011-07-29 17:02:34.535 Getting current directory name.
. 2011-07-29 17:02:34.535 Startup conversation with host finished.
< 2011-07-29 17:02:34.538 Script: Active session: [1] Knock3
> 2011-07-29 17:02:34.538 Script: put "D:\file1.php" "D:\file2.php" "D:\file3.php" ./noSuchFolderOnRemoteServer/
. 2011-07-29 17:02:34.538 Copying 3 files/directories to remote directory "./noSuchFolderOnRemoteServer/"
. 2011-07-29 17:02:34.538   PrTime: No; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2011-07-29 17:02:34.538   TM: A; ClAr: No; CPS: 0; ExclM(No):
. 2011-07-29 17:02:34.538   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2011-07-29 17:02:34.538 File: "D:\file1.php"
. 2011-07-29 17:02:34.540 Copying "D:\file1.php" to remote directory started.
. 2011-07-29 17:02:34.540 Ascii transfer mode selected.
. 2011-07-29 17:02:34.540 Starting upload of D:\file1.php
> 2011-07-29 17:02:34.540 CWD /noSuchFolderOnRemoteServer/
< 2011-07-29 17:02:34.778 550 /noSuchFolderOnRemoteServer/: No such file or directory
> 2011-07-29 17:02:34.778 CWD /
< 2011-07-29 17:02:35.015 250 CWD command successful
> 2011-07-29 17:02:35.015 MKD noSuchFolderOnRemoteServer
< 2011-07-29 17:02:35.258 257 "/noSuchFolderOnRemoteServer" - Directory successfully created
> 2011-07-29 17:02:35.258 CWD /noSuchFolderOnRemoteServer/
< 2011-07-29 17:02:35.498 250 CWD command successful
> 2011-07-29 17:02:35.498 PWD
< 2011-07-29 17:02:35.735 257 "/noSuchFolderOnRemoteServer" is the current directory
> 2011-07-29 17:02:35.735 TYPE A
< 2011-07-29 17:02:35.975 200 Type set to A
> 2011-07-29 17:02:35.975 PASV
< 2011-07-29 17:02:36.213 227 Entered Passive Mode (72,32,147,147,19,133)
> 2011-07-29 17:02:36.213 LIST
< 2011-07-29 17:02:36.688 150 Opening ASCII mode data connection for file list
< 2011-07-29 17:02:36.690 226 Transfer complete
> 2011-07-29 17:02:36.690 TYPE A
< 2011-07-29 17:02:36.928 200 Type set to A
> 2011-07-29 17:02:36.928 PASV
< 2011-07-29 17:02:37.168 227 Entered Passive Mode (72,32,147,147,74,31)
> 2011-07-29 17:02:37.168 STOR file1.php
< 2011-07-29 17:02:37.645 150 Opening ASCII mode data connection for file1.php
< 2011-07-29 17:02:37.883 226 Transfer complete
. 2011-07-29 17:02:37.885 Upload successful
. 2011-07-29 17:02:37.885 File: "D:\file2.php"
. 2011-07-29 17:02:37.885 Copying "D:\file2.php" to remote directory started.
. 2011-07-29 17:02:37.885 Ascii transfer mode selected.
. 2011-07-29 17:02:37.888 Starting upload of D:\file2.php
> 2011-07-29 17:02:37.888 TYPE A
< 2011-07-29 17:02:38.125 200 Type set to A
> 2011-07-29 17:02:38.125 PASV
< 2011-07-29 17:02:38.363 227 Entered Passive Mode (72,32,147,147,55,91)
> 2011-07-29 17:02:38.365 STOR file2.php
< 2011-07-29 17:02:38.835 150 Opening ASCII mode data connection for file2.php
< 2011-07-29 17:02:39.070 226 Transfer complete
. 2011-07-29 17:02:39.070 Upload successful
. 2011-07-29 17:02:39.070 File: "D:\file3.php"
. 2011-07-29 17:02:39.073 Copying "D:\file3.php" to remote directory started.
. 2011-07-29 17:02:39.073 Ascii transfer mode selected.
. 2011-07-29 17:02:39.073 Starting upload of D:\file3.php
> 2011-07-29 17:02:39.073 TYPE A
< 2011-07-29 17:02:39.310 200 Type set to A
> 2011-07-29 17:02:39.310 PASV
< 2011-07-29 17:02:39.548 227 Entered Passive Mode (72,32,147,147,149,191)
> 2011-07-29 17:02:39.548 STOR file3.php
< 2011-07-29 17:02:40.025 150 Opening ASCII mode data connection for file3.php
< 2011-07-29 17:02:40.265 226 Transfer complete
. 2011-07-29 17:02:40.265 Upload successful
> 2011-07-29 17:02:40.265 Script: close
. 2011-07-29 17:02:40.328 Disconnected from server
It did create folder automatically. Am I doing something wrong? or is it a bug or what?
OK, you are right. With (and only with) FTP protocol, WinSCP actually creates the destination directory if it does not exist. It is semi-bug.
Azamat
Can it be fixed in future versions of the program? Because it is important for what I do with WinSCP.
