File ext diff lower/UPPER Synchronize says "no differences"
HaWi
Hi all,
when I synchronize local and remote directories, and the file extensions lower/UPPER case differ, the WinSCP tells me "no diferences". But in fact it's crucial, on local machine it doesn't matter if file ext is lower or upper case, on server it does!
Is there a hidden setting I'm missing?
Thank for your advise
best regards
Ha Wi
Re: File ext diff lower/UPPER Synchronize says "no differences"
I understand your concern, but WinSCP is case insensitive just as any other Windows application.
