Address Bar Changes
Derimagia
Address Bar Changes
If you type an incorrect path in the address bar, currently the path resets to the directory is at.
What windows does (and in my opinion what it should do) is give the error message but not reset the directory. Then, if the user presses the ESC button it will reset the address to the directory. I use the address box a lot, and this would help a lot.
Re: Address Bar Changes
Thanks for suggestion. I have tried implementing that, but it showed not to be that easy. Will try again later.
