Error 9009
Devise
Brussels
Error 9009
When I execute my script, I get a errorlevel 9009.
Have you info about this error
Regards
Gary Lee
WinSCP batch job ends with Reason Code 9009
A question was asked about WinSCP Error Code 9009, to which the reply was given that WinSCP does not have an error code 9009. After receiving this code myself I did a bit of research. The code is apparently not from WinSCP itself, but rather from the underlying development product library (.NET ?), and indicates a malformed path for an error output file, causing the output file to not be found. In my case this was a redirected log output in a batch script that had run each day for quite some time, which implies that the error can be caused by an intermittent situation.
Example excerpt:
set /p RUNDATE=Enter text for RUNDATE (with no spaces):
<entered 20150219>
set LOGGING=C:\Production\SFTP_Servers\BALANCING\Logging
set BASE=C:\Production\SFTP_Servers\ClientA
set SFTPSCRIPTS=C:\Production\SFTP_Servers\Balancing\Windows_Scripts
winscp.com /script="%SFTPSCRIPTS%\SFTP_Script.txt" /parameter "%BASE%" >> %LOGGING%\%RUNDATE%.log
Seb
Re: Error 9009
I had the same return code as you (9009) and I found that was caused by the use of winscp.exe (instead of winscp.com). I just changed that and now my return code is 0.
Hope this helps.
RamonCar
España
Error 9009
I've also received this error using WinSCP.exe. I solved it by adding "option batch abort" and "option confirm off" at the begining of the script.
Also, be carefull on continuation character (^) if you're using a script. It must be the last character in the line. If there is a blank after it, cmd does not join follwing lines as command parameter to WinSCP. As WinSCP does not received the last command (usually "exit"), it enters interpreter mode, thus stopping the script.
Kind regards
Re: Error 9009
Documented here:
https://winscp.net/eng/docs/faq_batch_file#newline_escaping
