WinSCP TLS Explicit Encryption - Can't Transfer Files
bridrod
I am able to connect but when I try to upload/download a file, it gets stuck at 0% on WinSCP. Nothing gets transferred. I am able to duplicate this on different machines.
I am able to transfer files using Filezilla (command PROT P), CuteFTP (command PROT C), CoreFTP (command PROT P), WS_FTP Pro (command PROT C).
The command line option is one of the killer features some users cannot use anything else besides WinSCP.
I am using WinSCP V4.3.3 (Build 1340)
Thanks,
Re: WinSCP TLS Explicit Encryption - Can't Transfer Files
bridrod
NY
Email sent! Thanks!
bridrod wrote:
Please, let me know if you received the email (Subject=In Reference to Post - WinSCP TLS Explicit Encryption - Can't Transfer Files). Thanks!
Yes I did. Please allow few days for response.
