Install bug upgrading to WinSCP 4.3.3
John_P
Toronto
I'm trying to upgrade from WinSCP V4.3.2 to V4.3.3 and during the install I'm getting the following error:
regsvr32: "The procedure entry point Wow64EnableWow64FsRedirection could not be located in the dynamic link library KERNEL32.DLL"
Then I get error:
"C:\Program Files\WinSCP\DragExt.dll
Unable to register DLL/OCX: RegSvr32 failed with exit code 0xC0000139."
I'm using Windows XP SP3 (32 bit).
John
Re: Install bug upgrading to WinSCP 4.3.3
I wasn't able to reproduce the problem. Please run the installer with /log=path_to_log_file parameter and post the log file.
If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
