Cannot login but see in log that it was successfull.
hairydawgs
Here is the copy of my log...
It logs in successfully and then immediatly logs me off..never gives me a success window or files to view ect.. I have tried changing the default shell to /bin/bash.
WinSCP Version 2.1.0 (Build 119)
. Login time: Tuesday, January 14, 2003 10:04:57 AM
. Session name: hbennett@xxxxxxxxxxx.com
. Host name: xxxxxxxxxxxxx.com (Port: 22)
. User name: hbennett (Password: Yes, Key file: No)
. SSH protocol version: 1; Compression: No
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes
. Ping interval: 0 sec (0 = off); Timeout: 15 sec
. SSH Bugs: A,A,A,A,A,A,A,
. Proxy: none
. Shell: default, EOL: 0
. Local directory: default, Remote directory: home, Update: No
. Clear aliases: Yes, Unset nat.vars: Yes
. Looking up host "xxxxxxxxxxxxxx.com"
. Connecting to 65.80.49.86 port 22
. Server version: SSH-2.0-OpenSSH_3.4p1
. We claim version: SSH-2.0-PuTTY-Local: Jan 12 2003 19:45:16
. Host key fingerprint is:
. ssh-rsa 1024 a0:16:8b:dc:ab:0b:9e:37:6b:16:34:36:fd:85:73:e7
. Keyboard-interactive authentication refused
. Sent password
! Access denied
. Access denied
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Doing startup conversation with host (shell).
. Skipping host startup message (if any).
> echo "WinSCP: this is end-of-file:0"
< Microsoft Windows 2000 [Version 5.00.2195]
< (C) Copyright 1985-2000 Microsoft Corp.
[b]< (DAWGNUTZ) C:\Program Files\NetworkSimplicity\ssh>"WinSCP: this is end-of-file:0"[/b]
* (ECommand) Error skipping startup message.
. Closing connection.
Thanks... Much Appricated.
Haddon Bennett[b][/b]
Re: Cannot login but see in log that it was successfull.
WinSCP requires UNIX-style shell. Author of OpenSSH for Windows used to have description, how to setup WinSCP, but as the project is closed, it is not accessible any more.
I managed to get it running with the following settings:
Shell
- Shell: /bin/sh
- EOL characters: CR/LF [13/10] (Windows)
- Do not "Lookup user groups"
Just set up:
shell = /bin/sh
uncheck "lookup groups"
choose windows carriage returns
And map the default remote directory to one of your cygdrive mounts, e.g. /cygdrive/C
