WinSCP freezes when FTP service stops
zero
When WinSCP (4.3.3) has an FTP connection to a server (checked that with IIS) and this server stops the FTP service, WinSCP freezes.
Maybe it would be better to catch that error and display a "Server connection lost" or something similar.
mikew
I think I have the same problem
I am running winscp 4.3.3 and I am downloading around 250 files. Almost every time I run the program, it freezes. Each file initially registers as 0kb before registering the correct size and downloading. The program only freezes at the point when it displays the next file with size 0kb but before it updates to the correct size. Then blinking cursor next to a 0%, and only solution is quitting the command prompt.
Re: I think I have the same problem
