Feature: set local or remote directory as default directory.
FEATURE: When you click on remote/local panel add a option on the rightclick menu to set the current/selected directory as the default directory. (now it is only adjustable at the settings screen)
So: when i click on local panel and click on "set as default directory" then the current/selected directory wil be set as default local directory. And the same for remote directory/panel.
