Transfer Hidden Files
Riu
how can I upload a hidden file and keep the settings as "hidden"?
After uploading such a file, it gets visible.
I wanted to keep it as hidden, even if you download the file from the server.
Re: Transfer Hidden Files
If your server is Unix, you cannot do that, because on Unix hidden files have to have dot prefix.
There's no special functionality for that. Only protocol that specifically supports setting hidden attribute is SFTP version 4 and newer. But this version of the protocol is sparsely supported.
