How can I convert my Windows scripts to WinSCP scripts
Arvada Joe
Hi folks,
I am brand new to WinSCP. I need to send multiple files to a remote site in a secure ftp. Here are what my current scripts look like:
RUN.BAT
@echo off
REM ------------------------------------------
REM This batch file will run an ftp upload
REM then delete files on the current computer.
REM Start the upload
echo ----------------------------------
echo Start uploading at %TIME%
ftp -s:putfile.txt XXX.XX.XXX.XXX //runs the text file below
REM Done uploading, now delete the files on the local machine
echo Deleting local files
del D:\FTP_FOLDER\III to DOR\hello*.txt // deletes the files on my side after the ftp
REM copy over the files on the root to replace the one's just deleted
copy D:\helloworld*.txt
echo Upload complete at %TIME%.
Kicks off this file:
PUTFILE.TXT
jdoe // user name
jdoe // password
prompt
cd uploads
mput helloworld*.txt /files to be trasferred
bye
Thanks!
Re: How can I convert my windows scripts to winSCP scripts
First, you should read:
But, anyway:
RUN.BAT
winscp.com /script=putfile.txt
PUTFILE.TXT
option batch on
open sftp://jdoe:jdoe@XXX.XX.XXX.XXX
cd uploads
put helloworld*.txt
Inkster jim
Hi Prikryl
When I ran the code you gave me I got a "winSCP is not a valid win32 application".
I also got a "access denied"
Is there a certain location I need to run the batch files from?
Right now the files are 4 layers down. Does it have to be run with the path ie c:\program files\WinSCP script?
Can you give me a step by step process of how I need to do this.
Is a session necessary to do this like it is within the application?
To run the run.bat before I just typed bat. Is that what I do here?
As these probable are not WinSCP specific, you should better ask someone who can see the problem on your screen. This way we could hardly solve anything. I'm sorry.
millerintllc
I also got the same error after running that code. Now WinSCP.com doesn't seem to work. I would like to reinstall but I'm afraid it may lose my saved connections if I do so?
