error in SSLv2/v3 read
I can't get WINSCP to connect to a FTP site w/ SSL Explicit encyption.
The server certificate was issued by VeriSign and was fully trusted by the OS by default.
I can get this to work with CuteFTP but everything else I have done is using WinSCP - so I'd like to get it working with that.
I have queried "error in SSLv2/v3 read" but the results bring back no solutions.
Any ideas?
WinSCP Version 4.3.2 (Build 1201) (OS 6.1.7601 Service Pack 1)
< 2011-05-09 17:35:17.838 220 Service ready for new user
> 2011-05-09 17:35:17.838 AUTH SSL
< 2011-05-09 17:35:17.869 234 AUTH Command OK. Initializing SSL connection.
. 2011-05-09 17:35:18.103 SSL3 alert read: fatal: unexpected_message
. 2011-05-09 17:35:18.103 SSL_connect: error in SSLv2/v3 read server hello A
. 2011-05-09 17:35:18.103 Can't establish SSL connection
. 2011-05-09 17:35:18.103 Disconnected from server
. 2011-05-09 17:35:18.104 Connection failed.
. 2011-05-09 17:35:18.104 Got reply 1004 to the command 1
* 2011-05-09 17:35:18.109 (ESshFatal) Connection failed.
* 2011-05-09 17:35:18.109 SSL3 alert read: fatal: unexpected_message
* 2011-05-09 17:35:18.109 SSL_connect: error in SSLv2/v3 read server hello A
* 2011-05-09 17:35:18.109 Can't establish SSL connection
* 2011-05-09 17:35:18.109 Disconnected from server
* 2011-05-09 17:35:18.109 Connection failed.
* 2011-05-09 17:35:18.109 AUTH Command OK. Initializing SSL connection.
CUTEFTP 8.3
STATUS:> [5/9/2011 5:16:22 PM] Connected. Authenticating...
COMMAND:> [5/9/2011 5:16:22 PM] AUTH SSL
[5/9/2011 5:16:22 PM] 234 AUTH Command OK. Initializing SSL connection.
STATUS:> [5/9/2011 5:16:22 PM] Establishing SSL session...
STATUS:> [5/9/2011 5:16:22 PM] Connected. Exchanging encryption keys...
STATUS:> [5/9/2011 5:16:22 PM] SSL Connect time: 341 ms.
STATUS:> [5/9/2011 5:16:22 PM] SSL encrypted session established.
COMMAND:> [5/9/2011 5:16:22 PM] PBSZ 0
Re: error in SSLv2/v3 read
mhamberg
same issue with FTPS SSL_connect error
I am also experiencing the same error in trying to FTPS a file to a remote server. It says "SSL_connect: error in SSLv2/v3 read server hello A"
Did anyone figure out how to resolve this?
Log looks like this:
2011-08-26 15:35:43.785 Transfer Protocol: FTP
. 2011-08-26 15:35:43.785 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2011-08-26 15:35:43.785 Proxy: none
. 2011-08-26 15:35:43.785 FTP: FTPS: Implicit SSL/TLS; Passive: Yes [Force IP: No]
. 2011-08-26 15:35:43.785 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-08-26 15:35:43.785 Cache directory changes: Yes, Permanent: Yes
. 2011-08-26 15:35:43.785 DST mode: 1
. 2011-08-26 15:35:43.785 --------------------------------------------------------------------------
. 2011-08-26 15:35:43.925 Connecting to www.mysite.com ...
. 2011-08-26 15:35:43.957 Connected with www.mysite.com, negotiating SSL connection...
. 2011-08-26 15:35:43.988 SSL_connect: error in SSLv2/v3 read server hello A
. 2011-08-26 15:35:43.988 Can't establish SSL connection
. 2011-08-26 15:35:43.988 Disconnected from server
. 2011-08-26 15:35:43.988 Connection failed.
mhamberg
in addition
I should add I can connect just fine with Filezilla and this is my version of WINSCP:
WinSCP Version 4.3.4 (Build 1428) (OS 5.2.3790 Service Pack 2)
mhamberg
timing
Any idea when this bug will be fixed? I'd prefer to use WinSCP and not have to buy another FTP program. But I've got to get this up and running in the next two weeks.
Re: timing
I'll focus on it this week.
Re: update?
mhamberg wrote:
Is this working? Can we get an update?
Thanks for your help!
I've spent yesterday several hours trying to fix it. No luck so far.
Guest23
Team,
can anyone help in resloving the error which i am getting while connecting to FTPS using WINSCP.
I am not sure that i need to do as i am able to connect using other softwares like IPswitch ws_FTP and cute ftp.
Only not able to work with WINSCP.
Re: SSL Error
GordyM wrote:
Has an answer been found yet?
If you check the tracker link above, you'll find that the bug has been fixed and will be included into the next release.
rampike wrote:
I have the same problem - maybe it has something to do with certificates?
Have you tried 5.0.7 beta?
rampike
I have just tried 5.0.7 and get the same error. The graphical interface works fine, but /script function gives this error:
. 2012-05-14 12:38:44.843 Connecting to 10.0.0.51 ...
. 2012-05-14 12:38:44.843 Connected with 10.0.0.51, negotiating SSL connection...
. 2012-05-14 12:38:44.859 SSL_connect: error in SSLv2/v3 read server hello A
. 2012-05-14 12:38:44.859 Can't establish SSL connection
. 2012-05-14 12:38:44.859 Disconnected from server
. 2012-05-14 12:38:44.859 Connection failed.
cyberdem
USA
I am getting the same error (error in SSLv2/v3 read). downloaded version 4.3.8.0
Any idea?
I appreciate your great help.
Pathi
SSL3 alert write: fatal: bad record mac
Hi Martin,
We are getting thses errors continually. Kindly help me.
Thank you,
pathi
1.
TLS connection established. Waiting for welcome message...
Connection failed.
Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-SHA384, 2048 bit RSA, ECDHE-RSA-AES256-SHA384 TLSv1.2 Kx=ECDH Au=RSA Enc=AES(256) Mac=SHA384
Connection failed.
2.
decryption failed or bad record mac
(A)bort, (R)econnect (0 s): Reconnect
3.
Lost connection.
Connecting to <IP_of_server> ...
Re: SSL3 alert write: fatal: bad record mac
Please start a new thread for your problem and include a full session log file showing the problem (using the latest version of WinSCP).
RaduMan
Where did you download 4.3.8 from? It's over 6 years old. Please download the latest version:
https://winscp.net/eng/download.php
TLS connect: error in SSLv2/v3 read server hello A
Can't establish TLS connection
Connection failed.
In the version 5.13.7, downloaded today
Connection failed.
Please start a new thread for your problem. Include a full session log file. And also a log file from any other FTPS client showing a successful connection.
