Abort and Skip All doesn't work + remember last folder
icefront
Hi!
I have a bug report and a suggestion:
1. Uploading multiple files, when error occurs during upload, the Abort and Skip All buttons doesn't do anything, simply closes the dialog box and begins with the next file in queue. Skip All may need to skip all files if the same error occurs, Abort may need to clear the queue and stop all transfers.
I started to upload 1000 files, but the ftp was able to receive only 200. I may end clicking 800 Skip's or terminate WinSCP from taks manager
2. Important suggestion: please make an option to simply remember the last folder used, please don't save the last folder for every session. By this, I'll start ALWAYS from the last folder, regardless of where the last session was ended.
2a. When the last used folder cannot be accessed, there is no need to pop up a dialog saying 'c:\bla doesn't exists'. Frequently uploading from removable media makes this annoying dialog continuously appearing.
Re: Abort and Skip All doesn't work + remember last folder
I believe that by default WinSCP does not remember the last use directory. You you had to change the default settings. See https://winscp.net/eng/docs/ui_login_directories
icefront
Thank you for your answers!
1. Next time it will happen I will send you the log, until that I tell you the exact workflow:
- select multiple files to upload
- press F5 so the copy process starts with the first file, the others are in queue
- for some reason (it doesn't matter what, for example timeout or forbidden ftp access, etc.) the transfer stops, then a dialog pops up with multiple buttons like Skip, Skip all, etc.
Now, here the Abort button does not abort the uploading of the files that are in queue. The uploading starts with the next file, of course again the same error occurs, Abort, then comes the next file, and so on.
2. When the "Remember last used directory" is turned on, the last path of the session is restored. If the path isn't acccessible, a dialog pops up, that the path isn't accessible. This dialog may be useless, when often using removable media it's annoying (you may use a checkbox in the dialog "Don't show this again". Anyway, I understand this behavior.
My recommendation is a switch in the main options that skips the workaround of remembering directories for particular sessions, I mean GLOBALLY remember the last used directory. Otherwise I'm always landing in My Documents, I hate this folder - sorry.
So it's simple:
on main_window_open:
local_directory_panel.initialdir:=inifile.readstring(dir);
on main_window_close:
inifile.writestring(local_directory_panel.initialdir);
That simple.
Take my example: I'm working for microstock agencies. I have around 30 ftp sites set up. I upload the same images/videos for every site. I upload batches of 15-20 images or 4-5 videos of 20-200Mb. I often work from removable media, depending on the place (I have 3 computers) from where I upload. Depending on the other removable media inserted into system, the drive always changes. Now imagine, I start with the first agency, WINSCP says, F:\StockUpload doesn't exists. OK. When I connect to the second agency, WINSCP again says, F:\StockUpload doesn't exists. And so on for all the 20-30 connections. Also, every time I'm in the My Documents directory.
If you understand well, for this kind of work, complicated remembering of last used folders and/or repeated notifications it's just annoying.
Thank you!
As soon I will have a log I will post it here.
Jozsef
I wasn't able to reproduce the main problem.
