Error "Server sent command exit status 0."
guigui
Hi Pikryl,
I've got a weird problem with WINSCP 3.3.1
I'm trying to connect on a Solaris 8 box with Openssh 3.7.1p2
WINSCP is installed on several system and doesn't change nothing to the result : Win2000, WinXP...
It's working fine for almost all users but for only few I've got this message :
" Server sent command exit status 0."
Is this a problem of environment, of profile, of config files, ... ?
Do you have an idea ?
Best regards,
Guigui
Re: Error "Server sent command exit status 0."
Do the users have shell access? The best is to check server's log to see why it disconnectes the client.
