File Copy Confirmation
msenatore
I'm reading back the log file to confirm files were uploaded. Is there an indicator that confirms this? I.e. Is it the "Status code: 0" line that confirms that file "DEH_1768..." was sent?
Thx,
Mike
. 2011-04-25 10:31:30.940 File: "DEH_1768_20110414_143859.TXT"
. 2011-04-25 10:31:30.955 Copying "DEH_1768_20110414_143859.TXT" to remote directory started.
. 2011-04-25 10:31:30.955 Ascii transfer mode selected.
. 2011-04-25 10:31:30.955 Opening remote file.
> 2011-04-25 10:31:30.955 Type: SSH_FXP_OPEN, Size: 81, Number: 515
< 2011-04-25 10:31:30.986 Type: SSH_FXP_HANDLE, Size: 13, Number: 515
> 2011-04-25 10:31:30.986 Type: SSH_FXP_WRITE, Size: 4121, Number: 1030
. 2011-04-25 10:31:30.986 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-04-25 10:31:30.986 Type: SSH_FXP_CLOSE, Size: 13, Number: 1540
> 2011-04-25 10:31:30.986 Type: SSH_FXP_SETSTAT, Size: 81, Number: 777
< 2011-04-25 10:31:31.002 Type: SSH_FXP_STATUS, Size: 34, Number: 1030
< 2011-04-25 10:31:31.018 Type: SSH_FXP_STATUS, Size: 34, Number: 1286
< 2011-04-25 10:31:31.018 Type: SSH_FXP_STATUS, Size: 34, Number: 1540
< 2011-04-25 10:31:31.018 Status code: 0
< 2011-04-25 10:31:31.080 Type: SSH_FXP_STATUS, Size: 57, Number: 777
msenatore
Re: File Copy Confirmation
I couldn't find how to enable the XML logging from the command mode but when looking at the documentation, I did find the "put -delete" which I used and that is working for our needs now.
I did try enabling the XML logging in the GUI but that didn't take affect when running in command mode.
Thanks.
