Post login command field size limitation
FTPuser909
Could you please expand the size of the "Post login command" field. I need to send three lines of commands and as I type, it won't accept any more charcters about halfway through the third command.
Also, could scripting support the SITE command? This is what I need to send and cannot fit in the field and I thought scripting might be able to do it instead, but I don't see that as an allowed scripting command.
Thanks!
Re: Post login command field size limitation
Thanks for your post. This issue has been added to tracker.
Please read FAQ. If that does not help, come back.
