Can not transfer and copy file to server
Inst. of Global Concern
Tokyo
While trying to transfer file to the server, it is uploaded as size 0. (0 byte file is uploaded)
And after trying to overwrite it with the same file on the local, it gets a popup with following error message.
<Failure to copy file to remote>
Failure
Error Code:4
Message:Failure
Request Code:6
I don't understand the cause of error as no detail description is mentioned on the popup message
Using WinSCP 4.3.2 on Windows 7 / Transfer Protocol:SFTP-3
Thanks in advance.
Re: Can not transfer and copy file to server
Please post a full log file (on Debug 2 level) showing the problem.
Tokyo
Hi
Though I received an e-mail announcing that reply has been posted, actually I can not see the comment.
I would appreciate if you kindly check this.
Thanks.
