Location profiles lost when app hangs
mkn
This has been bugging me for years. I create half-a-dozen location pairs and due to some problems in the Internet connection WinSCP hangs. The only way to continue is kill the process. All my location profile additions are lost.
Is there a checkbox anywhere that would make it possible to save location profiles immediately?
Re: Location profiles lost when app hangs
Thanks for your post. This issue is being tracked already.
Anyway, I would be interested to find out why WinSCP is hanging for you. Are you able to reproduce the problem easily?
Hi, yes, this happens every time I forget that dragging and dropping a folder from the server panel to the workstation panel does that. Maybe the other way around as well. D&D is the key.
This happens every time on two different computers (Win7 and currently WinSCP 4.3.2).
And, yes, that also may happen after an internet connection has been lost for some time. I do not mind that but losing one's bookmarks is pretty irritating.
Aside from that no complaints!
Markku
