Blocking "Host ist not communicating for more than 15 ..."
ThomasKluge
This behavior does not make sense to me:
The Warning "Host ist not communicating for more than 15 seconds. Still waiting..."
Warning: Aborting this message will close connection!
If I press "Abort" the connection will be closed and reastablished.
Would like to have this automatically and none blocking, especially if I leave my PC allone uploading large files.
regards,
Thomas
Re: Blocking "Host ist not communicating for more than 15 ..."
Thanks for your post. This issue is being tracked already.
No, this issue is not resolved!
See my trace with the latest release:
. 2012-06-08 01:25:37.475 WinSCP Version 4.3.7 (Build 1679) (OS 6.1.7601 Service Pack 1)
. 2012-06-08 01:25:37.475 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
<snip>
. 2012-06-08 11:15:44.002 [Background 1] Waiting for dispatching send buffer timed out, asking user what to do.
. 2012-06-08 11:15:44.002 [Background 1] Asking user:
. 2012-06-08 11:15:44.002 [Background 1] Host is not communicating for 60 seconds.
. 2012-06-08 11:15:44.002 [Background 1] Wait for another 60 seconds? ()
<snip>
. 2012-06-08 12:09:27.429 Sending null packet to keep session alive.
. 2012-06-08 12:09:27.429 Sending special code: 15
. 2012-06-08 12:09:57.474 Sending null packet to keep session alive.
. 2012-06-08 12:09:57.474 Sending special code: 15
. 2012-06-08 12:10:27.904 Sending null packet to keep session alive.
. 2012-06-08 12:10:27.904 Sending special code: 15
<snip -> this is what happens after clicking on close icon>
. 2012-06-08 12:10:45.430 [Background 1] Attempt to close connection due to fatal exception:
* 2012-06-08 12:10:45.430 [Background 1] Terminated by user.
. 2012-06-08 12:10:45.430 [Background 1] Closing connection.
. 2012-06-08 12:10:45.430 [Background 1] Sending special code: 12
. 2012-06-08 12:10:45.430 [Background 1] Sent EOF message
. 2012-06-08 12:10:47.430 [Background 1] Looking up host "<removed>"
. 2012-06-08 12:10:47.430 [Background 1] Connecting to <removed> port 22
This behavior prevents unattended uploads. It is really annoying.
best wishes,
Thomas
As you can see in the tracker, this got resolved in 5.0.3 beta. You are using 4.3.7. Try upgrading. Let me know.
ThomasKluge
Yes it's working with this release but is somewhat unstable. I get messages like: "Invalid access to memory" and invalid drive access messages.
ThomasKluge
Berlin
I did not see this error again since I use version 5.1.2.
This is the first version for me which really does support unattended up-/downloads.
Thank you.
Thomas
Thanks for your feedback.
