"Console interface for WinSCP has encountered a problem"
WinSCP crashes if run from a directory path that is too long, e.g.
C:\Documents and Settings\xxxxxx\My Documents\_Projects\xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\xxxxxxxxxxxxxxxxxxxxxxxx\WinSCP.com
Re: "Console interface for WinSCP has encountered a problem"
I'm not able to reproduce this. Is this the actual path you have tried it with? How do you run WinSCP?
Okay, it must be something with my PC. The path I mentioned is the same but I substituted x's for the personal information. I run it by copying the .com and .exe files to a directory and opening a DOS prompt there. If WinSCP is in C:\ or a shorter path, it runs fine. This is with WinXP SP3, 3GB RAM.
