Can Not Overwrite Exisiting Files
gaspower
CA
I am trying to overwrite some files on a server, but I get an error that I have to delete file first and then upload? Is there away to automate this process so I do not have to press accept for each file? Also trying to understand why it can not overwrite? If I can delete, it should be able to overwrite without deleting first, correct?
Thanks JR
Version 4.2.7[/img]
Re: Can Not Overwrite Exisiting Files
Please post a full log file showing the problem (using the latest version).
