error transferring file
igor
Hi!
During download from FTP I have at the end of this error:
Error transferring file '/ord-stand1.tar.gz'.
Copying files from remote side failed.
Restart offset 8492211029 is too large for file size 8492211029.
Restart offset reset to 0
mmp_init(): Bad file descriptor
0,014 seconds (measured here), 9768242187.56 Mbytes per second
Does anyone know why?
Re: error transferring file
