WinSCP freezes
peto
WinSCP freezes
I use WinSCP mainly for FTP sites. And this error occurs very often, when WinSCP is connected and idle for some time. First, it gives me error like timeout and then I get this error:
Error getting name of current remote directory
Invalid response to PWD command 'MDTM
MFMT
TVFS
MFF modify;UNIX.group;UNIX.mode;
MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
REST STREAM
SIZE
I click OK and then [code] tries to reconnect (probably) – I can see only small blank window and whole program is frozen. Only way to close it is to kill winscp.exe via taskmanager or similar program.
I use FTP protocol with passive mode and this happens not only on one server.
Am I doing something wrong?
peto
sorry, I forgot
WinSCP version: 4.3.2
(before this version, I was using ver 4.2.9 and I didnt noticed this bug, but I am not sure)
Windows Vista SP2
Re: winscp freezes
elraver
Same problem...
I'm sending you my email for a debug version as well due to having this issue. It simply freezes seemingly at random. I'll go to do some editing on a file for about 10 minutes, and when I come back to the WinSCP window to upload it, it is frozen (Not Responding) and has to be killed and reopened.
-elraver
neijygof
Re: winscp freezes
I am having the same problem... may I send you an e-mail requesting the debug version?
Thank you in advance,
neijygof
Re: winscp freezes
Sure. But first, pleae make sure you are using the latest version of WinSCP.
kag wrote:
I'm having the same problem and I'm running 4.3.3 build 1340 on Windows XP SP3.
I have sent you an email.
consistency
consistency avatar
austria
I have a similar "problem" with SSH connections (for all my 4.x WinSCP versions). If I connect to an IP in my LAN where no SSH server is running, WinSCP runs in a timeout without leaving me an option to cancel the try of WinSCP to connect.
Here I connect to an local network IP where no SSH server is installed:
also if I know that WinSCP can't connect because I have to start/install SSH server first I have to wait (in my case 22sec) for WinSCP to show me the following error window:
and then I only have 5sec to press ok, if a miss to press the ok button I have to wait another 22sec in the "freeze mode" until the error window reappears and i can press ok.
It would be great to let WinSCP try to connect in background but leaving me the option to cancel the connection try.
