Directory Uploading Failing
Breno
Hello!
I got a user called gravacoes (its group also is called gravacoes), with the following permissions on the "administrador" directory:
directory:drwx--x--x 2 gravacoe gravacoe 4096 Jan 27 14:04 administrador/
When I try to upload an empty folder (directory) that is in my computer, the program crashes with the following message:
Access violation at 0055BCF1 in module WinSCP3.exe
Read of address FF00000C.
Any ideas of what's going on?
Thnks in advance!
Breno
_________________
Breno R. B. Marchetti
Re: Directory Uploading Failing
What version of WinSCP? What protocol (SCP/SFTP)? Does it happen with every directory, or only empty directory or only the one particual directory? Any destination directory? How do you upload the directory (hot key, drag&drop, etc)? Thanks.
Hello again!
Well, i am using winscp Version 3.5.0 Build 204, and the protocol is SFTP (allow scp fallback).
It happens with both empty folders (almost 100% of the time) and full folders, in the event drag and drop from my local computer to a remote host.
I am uploading to the directory
directory:drwx--x--x 2 gravacoes gravacoes 4096 Jan 27 14:04 administrador/
I am using the user gravacoes, that belongs to the group gravacoes (this group can write in the folder administrador as shown).
Any idea? Thanks!
