WinSCP deletes Temp Files WHILE THEY ARE OPEN!
Guest01
So I have WinSCP setup to use Notepad++. I open 6 (really 1+ causes this) files at the same time. Everything is good, but then I switch over to WinSCP, just look at it, then give Notepad++ focus again and bam! "Such and such file doesn't exist any more, keep it in the editor?" Happens to the first 3 files I opened. I can work in the files just fine, but when I give WinSCP focus for a second and then go back to Notepad++, it deletes the rest of the remaining temp files until their is just 1 left, then that 1 will stay and never get deleted until I want it too.
What the hell is going on? I have been twisting and changing the settings for several hours with no change to the behavior.
Re: WinSCP deletes Temp Files WHILE THEY ARE OPEN!
Re: Same problem
adals wrote:
I have the same problem since I migrated to Windows 10
The same answer:
