get and mv commands
natha
get and mv commands
Considering following script:
option batch abort
open <SomeName>
cd /UNRATED
option transfer binary
get *.txt E:\DATA\SUPPLIERS\
mv *.txt /UNRATED/Archive/
close
Will the "mv" command only move the files downloaded with the "get" command?
Or will it move also files that have been added in the meanwhile?
I explain myself:
Let's say I "get" 100 files.
After command finished executing, 1 more file is added in remote directory.
Will the "mv" move 100 or 101 files?
Thanx
Re: get and mv commands
This is true.
To move just downloaded files, use XML logging, parse the log to find out what files were transferred, and generate move script based on that.
I'm in process of creating some examples for tasks like that. You can see incomplete article at:
https://winscp.net/eng/docs/guide_interpreting_xml_log
