blackcat
Assertion failed: xdrPtr && xdrPtr == *xdrLPP, file xx.cpp, line 2233
Site Admin -
- 43,074
- Prague, Czechia
Re: Assertion failed: xdrPtr && xdrPtr == *xdrLPP, file xx.cpp, line 2233
darcan
WinSCP3.exe
OK
My OS: Win XP.
Uploading to linux.
WinSCP 3.5
Site Admin -
- Guest
I'll look at it. But I have not idea yet what may cause this.
I am getting this exact error as well.
- Guest
win2k
GPHemsley
Local OS: Windows XP Professional
Remote Host: projects.sourceforge.net
Error:
and after clicking OK:Assertion failed: xdrPtr && xdrPtr == *xdrLPP, file xx.cpp, line 2233
Abnormal program termination
Site Admin -
- Guest
To all: Under what circumstances do you get the error? Is it also while uploading large files as "blackcat" reports?
Receiving the same error. Intermittent with any kind of folder/files to a Linux box. The error is consistent even if it occurs at differing times during transfer.
NOTE: Frustrated, I returned to using WinSCP 2 and had no further problems. I was unable to reproduce the problem transfering the same files to the same host. Delete the folder, and try again with WinSCP 3.5, and error returns.
What can I do to assist?
Richard Harmonson
MCSE/CNE/RHCE
- Guest
Richard Harmonson
MCSE/CNE/RHCE[/quote]
Site Admin -
- 43,074
- Prague, Czechia
I would appreciate if you can try newer version (like 3.0) to determine when the problem was introduced. The error never happens to me so I have no idea what may cause this.NOTE: Frustrated, I returned to using WinSCP 2 and had no further problems. I was unable to reproduce the problem transfering the same files to the same host. Delete the folder, and try again with WinSCP 3.5, and error returns.
Thanks in advance. Please let me know.
- Guest
Be happy to try WinSCP 3, but not seeing it as an available download. I may be going blind. Where?
I will test tonight and post results.
Richard Harmonson
richard at kinetotech dot com
Site Admin -
- 43,074
- Prague, Czechia
All old versions of WinSCP are on the Sourceforge download server. The link is on Downloads page.Be happy to try WinSCP 3, but not seeing it as an available download. I may be going blind. Where?
Thanks in advance. If you are able to reproduce the bug easily, than I would ask you to try more versions to find one that introduced the bug. If it is not easy than try only 3.0 now. If it is fine, I'll try to suggest some other that may have been the first faulty.I will test tonight and post results.
Avenger
Desktop OS: WinXP with WinSCP 3.5.0
Server OS: Fedora Core 1
It is reproducable 100% for me if I try to upload 10 directories to an empty directory on the server. I am also getting "Null Pointer Termination" dialog boxes appearing at random times.
WinSCP 3.4.2 is currently uploading the same files to the same empty directory without any problems at all.
--Keith
Site Admin -
- 43,074
- Prague, Czechia
Thanks!It is reproducable 100% for me if I try to upload 10 directories to an empty directory on the server. I am also getting "Null Pointer Termination" dialog boxes appearing at random times.
This might help. I'm able to reproduce the error now. I need to try it in the evening at home with debugger. I hope it will be reproducible there to.
It also happens to me only with 3.5, not with 3.4.2 and mainly not with upcoming version of WinSCP (3.5.5).
If others can confirm that the error happens only with 3.5, I would appreciate it.
GPHemsley
The error did not occur with 3.4.2. :mrgreen:If others can confirm that the error happens only with 3.5, I would appreciate it.
Site Admin -
- 43,074
- Prague, Czechia
Thanks! That's good. I believe that the bug is then releated to another problems introduced in 3.5 likeThe error did not occur with 3.4.2. :mrgreen:
- Problem with 3.5 version
- V3.5 under w2k and wxp can't change to /cygdrive - access failure
So it will be fixed in the next release (in fact it is already).
- Guest
Sorry for the delay, but once I had a working WinSCP, I was busy using it to complete a large migration.
WinSCP 3.4.2 worked perfectly. I moved over 250 gb without issue. Not a single error.
Thank you!
Richard Harmonson, CNE/MCSE/RHCE
iRex
assertion error fix
Thanks.
PS This is an incredible piece of software, even for a a "non-programmer"
Site Admin -
Re: assertion error fix
At the end of this week.Can you tell us when the version with the fix will be available?
- Guest
Will that be WinSCP3 v.3.5.1?
David
getting same error
Site Admin -
That will be 3.5.5. But I do not understand what difference it makes to you? :?:Will that be WinSCP3 v.3.5.1?
me
access violation at address 0055bcf1 in module 'winscp3.exe'. read of address ff00000c
winscp3 ver 3.5 build 204 drag and dropped the folder with files in it to thhe remote location
scp/sftp root priveledges on remote and admin privledges on local
win 2k professional uploading to aa linux carton
Site Admin -
- 43,074
- Prague, Czechia
Re: access violation at address 0055bcf1 in module 'winscp3.exe'. read of address ff00000c
Can you reproduce the error with the latest version (3.5.6)?winscp3 ver 3.5 build 204 drag and dropped the folder with files in it to thhe remote location
- PollyVinylChloride
- 1
- Croydon, London
SFTP Problem...
I've been evaluating the Java SSH Daemon which comes with an open-source package known as SSHTools. I've successfully logged into the daemon using Cygwin SSH and Putty. I've also successfully accessed the daemon's SFTP subsystem using the Cygwin SFTP client. However, although I can successfully authenticate to the Java daemon using WinSCP, I cannot proceed beyond that point. The session times out, every time. I have tried increasing the timeout interval without success.
I've logged both the WinSCP and Cygwin SFTP sessions, but as I'm ignorant of the protocol, the log doesn't mean that much to me.
There is a point at which something seems obviously to fail, and the following is an excerpt from the WinSCP log at this point:
> Type: SSH_FXP_INIT, Size: 5, Number: -1
. Waiting for data timed out, asking user what to do.
If you have any suggestions as to how I might proceed, I would be most grateful.
Site Admin -
- 43,074
- Prague, Czechia
Re: SFTP Problem...
First of all, try to enable logging on the SFTP server side, if the server allows it. Post the log.. Doing startup conversation with host.
MichaelMR2
This Error Cropping up again
Site Admin -
- 43,074
- Prague, Czechia
Re: This Error Cropping up again
Can you send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.I'm getting this exact error again, Version 4.3.2 :|
- Guest
For what it is worth, I just receive this error as well with v4.3.6; Trying the 5.0.5 Beta right now... This was on a 64-bit Windows 2008 R2 with a relative large file 75mb.
Site Admin -
Please let us know results of your 5.0.5 test.For what it is worth, I just receive this error as well with v4.3.6; Trying the 5.0.5 Beta right now... This was on a 64-bit Windows 2008 R2 with a relative large file 75mb.
