Automating winscp in VB 6
Dan Tabernsky
I know this might sound a little bit annoying(especially if this this post is already redundant), I need to know if I can create a variable in winscp to pass an error message from the linux server to winscp to the windows client.
Right now I am using a VB 6(Jurassic, please spare the hate) to automate the process of starting a Virtual Box Machine from a Windows XP to Linux Fedora. I already been able to automate the process of starting and putting it to savestate using your winscp(Astig, di ba? BTW I am not a native english speaker) but I am having an issue on error-trapping it since the only variable that I can count on is the exit code.
First question, is there any variable I can use to pass the error message from linux to your winscp and pass the error back to VB?
Second question, can I know the more details(other than the website) regarding the "ECHO" command in option? Since in other PLs it can be used as a return statement to give accurate error messages.
I know sound like a real ahole(in fact I am) in leeching your program and asking questions(if not stupid) but I like your program and will continue to use and endorse it to my colleagues and friends(sorry, living in a 3rd-world is a real pain so for now I won't be able to donate).
Dan Tabernsky
Another Question
I'm sorry for being rude but I would like to ask another question.
Can I know why is winscp reporting an error message when using a call command of savestate in linux?
Here is the situation:
First, using a windows client I open the winscp through command line
Second, opening the connection using IP address:
"open XXXXX:XXXXXX@XXX.XXX.XX.XX"
Third, after opening the linux computer I use the code:
"call vboxmanage startvm /XXX/XXX/XXX.vbox"
to open the the virtual machine
Fourth, after playing around the virtual machine inside linux I put in the code:
"call vboxmanage controlvm XXX savestate"
the output that I got on putty was like this:
"10...20...50...80...90...100%"
but in winscp I got was this:
"Command vboxmanage controlvm XXX savestate"
"failed with return code 0 and error message"
the command will still go through but the winscp will give an error code 1 because of that
Can I know what went wrong?
I do apologise for my behavior in the last post.
Re: Automating winscp in VB 6
You cannot set any variable in WinSCP. Btw, what is source of the message you want to pass back?
Re: Another Question
WinSCP reports error when the custom command prints anything on the error output. You can possibly prevent that by output redirection:
call vboxmanage controlvm XXX savestate 2>&1
Though it is just suggestion, I haven't tried that.
Dan Tabernsky
Thanks for replying! :D The suggestion was very appreciated but your logs were so useful to the point that I just created a function to read the text in the logs and get the exact output made by the linux machine to provide an output if the command worked or not!:D
All I needed was to study your Guides!
Thank you so much for giving your Winscp the Absolute Return Statement that I need! :D
Also, thank you so much creating such a COOL(Astig) program! :D
