Log file not generating.
wmb853
I am working on an issue and need to generate a log file. I am running WinSCP from a bat file below:
c:\WinSCP\WinSCP3.exe /console /script="c:\EMT\AutoFTP.txt" /log="C:\EMT\winscp.log"
No log file ever gets generated. Thanks.
Re: Log file not generating.
I just upgraded to the latest version. I never see the winscp.log file get created in the C:\EMT folder or anywhere else.
I should also clarify that the FTP upload is working correctly. I just don't get a log file.
Thanks!
Bill
tdguitar
Can not create log file
I have a function with creating log xml file like below. It run well on local machine, but when I publish it to be used as client-server, it can not create a log file. Please help me to check it.
const string logname = "log.xml";
Process winscp = new Process();
winscp.StartInfo.FileName = "C:\\Program Files\\WinSCP\\winscp.com";
winscp.StartInfo.Arguments = "/log=C:\\"" + logname + "\"";
winscp.StartInfo.UseShellExecute = false;
winscp.StartInfo.CreateNoWindow = true;
winscp.Start();
winscp.StandardInput.WriteLine("option batch abort");
winscp.StandardInput.WriteLine("option confirm off");
winscp.StandardInput.WriteLine("open mysession");
winscp.StandardInput.WriteLine("ls");
winscp.StandardInput.Close();
string output = winscp.StandardOutput.ReadToEnd();
winscp.WaitForExit();
XPathDocument log = new XPathDocument(logname);
XmlNamespaceManager ns = new XmlNamespaceManager(new NameTable());
ns.AddNamespace("w", "http://winscp.net/schema/session/1.0");
XPathNavigator nav = log.CreateNavigator();
XPathNodeIterator files = nav.Select("//w:file", ns);
Console.WriteLine(string.Format("There are {0} files and subdirectories:", files.Count));
foreach (XPathNavigator file in files)
    Console.WriteLine(file.SelectSingleNode("w:filename/@value", ns).Value);
LukeHuang
I cannot generate log file with 5.1.2 suddenly...
I cannot generate the log file with 5.1.2 suddenly. Can anyone help?
Thanks,
Re: I cannot generate log file with 5.1.2 suddenly...
@LukeHuang: First of all, please upgrade to the latest version of WinSCP.
If that does not help, we need way more details. What prevents you from generating the log?
Re: After update to 5.19.5 – will not log
@jensohb: We need some information. What version where you using before? Is this about GUI or scripting? If scripting, what does the WinSCP console output say when it fails to log? What (if) command-line syntax are you using?
