Invalid access to memory when using /defaults option
rbedger
Windows 7 Home Premium 64bit
Error occurs when attempting to use the /defaults option for /keepuptodate.
Without the /defaults option everything works as it should. The upside of this bug is that WinSCP will continue functioning normally in keepuptodate mode if you don't click "Ok" on the error popup.
rbedger
Re: Invalid access to memory when using /defaults option
What version of WinSCP are you using?
sorry, using 4.3.2 build 1201.
I cannot reproduce this.
