SSIS package scheduled in SQL agent.
KDG
I have multiple packages that runs with WinSCP.com using Execute process task, it is in FTPS implicit protocol. the problem now is some of my package is failing to send to the FTP, i already read the FAQ, i already implemented the certificate='...'. when i run it manually using the job it successfully done and it send to the FTP but when the job execute automatically it sometimes indicates a problem and its recurring.
i also get some errors of The process exit code was "1" while the expected was "0"
but when i see the FTP path the file is sent.
any suggestion for this? Thanks in advance.
Re: SSIS package scheduled in SQL agent.
KDG
Hi Mark,
just a question if why Execute Process task is in failed status after exiting the WinSCP.com? I am still not sending the logs yet.
Thanks,
Well, that's what I want to find out from the logs.
KDG
Hi Martin,
Yeah, I realize that also after posting it. sorry for my stupid questions.
but I think this is not a stupid question anymore.
Does WinSCP has a timeout? for example my package(with WinSCP) is still running and not yet finish but my other package start now getting started which has also a WinSCP would you think connecting on the same time on a same computer can affect the connection between my First package which is first connected to the FTP and the second package which is now connecting?
Thanks for fast reply Martin!
Best regards,
Jeric
Best regards,
Jeric
wmb853
KDG wrote:
Hi Mark,
Thanks,
Are you asking why the Execute Process task DOES NOT report an error or why it DOES report an error? Are you able to get the log to work? I have the following in a bat file and it won't log anything.
c:\WinSCP\WinSCP3.exe /console /script="c:\EMT\AutoFTP.txt" /log="C:\EMT\winscp.log"
KDG
wmb853 wrote:
KDG wrote:
Hi Mark,
Thanks,
Hi There,
Are you also seeking for help? try to add session on your line. Please see documentation Logging. I hope it helps you.
Regards,
J
[quote="KDG"]Does WinSCP has a timeout?[/qoute]
Timeout for what?
In general no. But if you are manipulating some files, the two processes may get into conflict.
