How do I reset the UI
LazyTiger
Well, I haven't locked the toolbar and accidently rearranged the icons 2 or three times. Is there an option or a trick to reset it?
Re: How do I reset the UI
You can remove HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\Commander (or Explorer).
Re: And for portable version?
Remove all section like [Configuration\Interface\Commander\*] from the INI file.
bheem
Reg forget winscp password
Dear Sir
I had forget admin password i am unable to login winscp.
if i reset winscp whether data will be loss or what.
