Explorer view - .. shortcut to parent
I was wondering if there is a way to get the .. shortcut to go up one level to the parent directory in the main window in Explorer view? Commander view has this, but I prefer Explorer view as I do not use the Local panel too often.
Thanks!
Re: Explorer view - .. shortcut to parent
There's no way. You can use many other ways to get to parent directory. Backspace key, Ctrl+PgUp, toolbar icon.
Yury Plashenkov
Dear Martin,
Is there any chance you will add the option to show a ".." (parent folder) shortcut in Explorer view?
It would be very nice. Sometimes I drag and drop files to this shortcut to move them to a parent folder, but since I switched to Explorer view, I cannot do this. Sure, there is a perfect folder tree in Explorer view, but I think the option to show ".." will not be excess.
Thank you and good luck!
Sincerely,
Yury Plashenkov
MPLewis
Has any progress been made on this issue? Having the ability to go back up a directory in the explorer window would be fantastic for me.
