VB.NET and Multiple URLs
ChaZ
I am wanting to create a VB.net program that automatically uploads files to 1 of 2 locations (different URLs but with same login and password). But then downloads files from 1 location.
- Is it possible to create such a program in VB.net that would automatically do this without having to open WINSCP?
hmansoor
Re: VB.NET and Multiple URLs
Should be possible. What problems are you having in particular implementing this?
I am not sure how to go about it, You see i am hoping to find an API/PlugIN which i can reference in my Vb.Net project and then login to a server, copy some files from the local server to the remote server.
I am confused how to go about it.
