Same names files downloads from Linux OS to Windows OS
I have the current scenario and need some help:
Trying to download files from Linux OS to Windows OS, these files have exactly same names on Linux
Folder but when copying them files to a Windows based OS Folder the files with the same name can not be
Copied on to the Windows Folder unless files are renamed.
I have to manually rename these files so I can copy them on to the windows folder. The number of files
with the same name are growing and doing this as a manual process is painful
Sample as follows
"On Linux Server OS"
There is a folder called \var\vpn
Sample of 2 files on the folder with same name are:
name.xml
NAME.xml
Note the same name but case sensitive
Linux Supports having files with the same on the same folder as long as the files are typed differently
lower case / upper case
Any hints to come up with a script that allows WinSCP to get these files downloaded on to Windows based File System Folders ??
manuelbrozo
Aust
Trying to get WinSCP to rename similar files or add at least two characters to the begining of the file as an example
Files with the same name WinSCP to download them and rename the file downloaded by adding an "x-" to the beginning of each file
Lets say if Name.xml and nAme.xml are found download both files but rename nAme.xml to x-nAme.xml or get nAme.xml to be saved on to a separate Folder on the Windows File System
This is what I am currently doing but manually..
Reply with quote E-mail
OK, WinSCP could do this, if both files are part of the same download batch. Is this your case? If you already have name.xml in local directory and you are downloading Name.xml, WinSCP cannot know, if those files are the same or different.
Any chance if you can tell me what command to use on the script or a script to achieve this ??
Thanks a lot in advance !!
There's no way to achieve this. I was just asking to understand your problem, so I can think of possible implementation to solve it. Of course when I find that more people would benefit from it.
ChuckNewman
Have WinSCP create files with original names
According to Microsoft <invalid hyperlink removed by admin>, NTFS *does* support unique filenames that differ only in case. Read the KB for details.
Some of the files on the *N*X I use fall in this category. It would be nice (for me, at least) if WinSCP would copy them onto an NTFS file system as-is without me having to rename files with case-name conflicts.
In my case I'm just using Windows as a back-up repository; I'll only actually *USE* the files after copying them back to a Linux system (if needed).
Re: Have WinSCP create files with original names
OK, but Windows does not support them.
