Can the Winscp plugin cause a Far UAC prompt if necessary
zippy1981
Queens NY, USA
For the past few versions, Far 2.0 has an internal UAC prompt of sorts if performing a local file operation See <invalid hyperlink removed by admin>. It does not seem to get triggered by the winscp plugin when I want to copy from a sftp share to a local folder that requires admin access. Is it possible to add this feature?
Regards,
Justin Dearing
justyjusty123
UAC
I also noticed this issue: I downloaded files and cound not find them in a directory. WinSCP did not send notifications for this.
justyjusty123
Vienna
Dear Martin,
I just wanted add that I recognized this issue (copying file from one tree to a 64bit-Windows host) with both the stable version 4.53 as well as with the Beta, 5.0.6
As we use WinSCP a lot, we are looking forward for a solution for this. You can contact me any time with questions for details.
Please direct your request for Far-NetBox project:
https://github.com/michaellukashov/Far-NetBox
