error when running a put command
I am trying to copy files from the Windows 2003 Server to a Linux machine using WinSCP
Any ideas? Btw, I couldn't find the .ini file in the
put
command. I got the following error after the copy completed to 100% for 1 of the files:
The file transfers no problem when I tried running it manually with the WinSCP windows interface.Error deleting file 'myfile'. After resumable file upload the existing destination file must be deleted. If you do not have permissions to delete file destination file, you need to disable resumable file transfers.
Error code: 4
Error message from server: Failure
Request code: 13
(A)bort, (R)etry, (S)kip, Ski(p) all: Skip
program files/winscp
. And since this is a server, I don't have access privilege to the c:\users\
folder or the registry where the .ini file might be stored. Is there a way to modify the resumable file transfer within the command line? Btw, this copy command is not trying to replace an existing file in the destination location...
