error: Your security settings do not allow to open ...
flash1000
system : windows 7 family edition
winscp version :: 4.3
external text editor :: notepad++ or pspad
When trying opening files after establishing connection to one of my webservers I get following windows system alert message saying : Your security settings do not allow to open one or several of file(s) ...
Remark: I use french windows 7 and I tried to translate the error message the best I can.
This message disapears when I use the internal WinSCP text editor.
Why I'm suddenly unable to open files with external text editors? ... this happend also with the standart notepad editor from windows 7!!! Two days before eveything worked fine.
I desinstalled winscp and reinstalled it but the windows error message doesn't disapear when using external text editors.
Can Somebody help.
Thanks.
Re: error: Your security settings do not allow to open ...
I do not think this error message is coming from WinSCP. It is rather coming from Windows. Maybe you are not allowed anymore to open files in temporary folder. Can you try to create text file in temporary folder (in Windows Explorer) and double-click it to verify?
