Resume Problem
agent0815
Resume Problem
I am using WinSCP to upload our home videos on the PC of my parents with FTP. Quite offen files are left broken or incomplete. Since the files are quite big I don't really want the send the whole file again. Now the problem is that if I click on the resume option, WinSCP seems to continue where it stopped and transfers the remaining part fine enough, but after the copy window has closed the file is still incomplete and in the same state as before the resume. Has anyone an idea why??
Re: Resume Problem
