tar/untar commands inactive
xdra
Hallo,
I'm trying to untar a package on my server, but untar command is inactive.
Do i have to install some additional software to use this commands?
Thanks in advance for any help.
Re: tar/untar commands inactive
That may be correct answer. Custom commands are supported for SCP and SFTP (via secondary shell session) only.
Also you need to have the archive file selected on the remove file panel.
srikanth
India
only FTP is supported
My server supports only FTP connections,if i select SCP/SFTP it does't allow me login.
Is there a way to unTar in FTP mode of connection?
Reply with quote E-mail
