Copying files from remote side failed
adhar
ADHAR
I am downloading a folder gld02 of size 83GB from my linux server(RHEL 5 update 6) to my local pc. I am using winscp 3.7.6.306 in my pc to download that folder. But after 1 hours of download the following error msg is showing
Copying files from remote side failed.
General failure (server should provide error description)
Error code: 4
Error message from server: Failure
Request code: 5
I tried 2 to 3 times to download. But every time noticed that after every 1 hours the same error is comming.
For your information, I used the same executable for downloading from linux servers (more than 80GB) in the past but never faced this issue. At that time the server was running on RHEL 5 update 4.
Looking forward for your kind help!
Regards,
Re: Copying files from remote side failed
adhar
ADHAR
Thanks for your reply.
I am new to linux and winscp. Can you please let me know the steps for enable logging and the path to find the log file.
Thanks and regards,
