Refresh Remote View
adem
Refresh Remote View
How can I Refresh the right pane (i.e. the remote view).
Reason I am asking this, after I do a 'chmod -R squid.squid *' I can not get it to display the new state unless I start a new session.
TVMIA,
Re: Refresh Remote View
Ctrl+R in Norton Commander interface or F5 in Explorer-like interface. You will find it in menu too. There is also the button for this on toolbar (two rounded green arrows). If you want WinSCP not to cache the directories, you may disable the feature on 'Environment' tab of Login dialog.
